Corded Tools
DREMEL® TRIO (6800-3/8)
The new Dremel TRIO is the ultimate tool for everyone involved in general handson projects in and around the house. The Dremel TRIO has a 3 in 1 Spiral System which enables you to cut, sand and rout with 1 and the same tool. This versatile, compact and lightweight tool is very powerful! The Dremel TRIO has superior ergonomics, a 2 position handle and variable speed which ensures the most optimal rate of working in different materials. With its 360° spiral cutting technology and plunge-cut ability, the tool makes quick and freehand cuts in wood, plastic, drywall, metal, and wall tile. Next to that there are also dedicated TRIO sanding and routing accessories and attachments, so this tool will complete your project from start to finish! Dremel Trio 3 in 1 Spiral System: Cut, Sand and Rout.
Technical details for DREMEL® TRIO (6800-3/8)
Technical specifications
Rated power input
200 W
Voltage
230 - 240 V
Weight
1,20 kg
21.5 cm
No load speed
10.000 - 20.000 1/min
No load speed (3)
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
71 dB(A)
Sound power
82 dB(A)
Vibration
2,2 - 5,1 m/s²
Included Accessories (9)
Delivery details: DREMEL® TRIO (6800-3/8)
Dremel Trio
1x TR407 Sanding Mandrel
3x TR408 Sanding Band P60
3x TR432 Sanding Band P120
1x TR563 Multipurpose Carbide Cutting Bit
1x TR654 Straight Router Bit
Compact Foot
Vacuum Cleaner Attachment
Line and Circle Cutter Attachment
Inspiring welcome poster
Instruction manual
Sturdy and spacious storage case
Dedicated accessories for use with Dremel Trio only.
Product box length, 39.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Gross weight, 2,90 kg
F0136800JB
8710364052646
8710364052646
