Retired Products
DREMEL® TRIO (6800-3/8)
Retired Products
The new Dremel TRIO is the ultimate tool for everyone involved in general handson projects in and around the house. The Dremel TRIO has a 3 in 1 Spiral System which enables you to cut, sand and rout with 1 and the same tool. This versatile, compact and lightweight tool is very powerful! The Dremel TRIO has superior ergonomics, a 2 position handle and variable speed which ensures the most optimal rate of working in different materials. With its 360° spiral cutting technology and plunge-cut ability, the tool makes quick and freehand cuts in wood, plastic, drywall, metal, and wall tile. Next to that there are also dedicated TRIO sanding and routing accessories and attachments, so this tool will complete your project from start to finish! Dremel Trio 3 in 1 Spiral System: Cut, Sand and Rout.
User Manuals
- Dremel Trio
- 1x TR407 Sanding Mandrel
- 3x TR408 Sanding Band P60
- 3x TR432 Sanding Band P120
- 1x TR563 Multipurpose Carbide Cutting Bit
- 1x TR654 Straight Router Bit
- Compact Foot
- Vacuum Cleaner Attachment
- Line and Circle Cutter Attachment
- Inspiring welcome poster
- Instruction manual
- Sturdy and spacious storage case
- Dedicated accessories for use with Dremel Trio only.
- Product box length, 39.2 cm
- Product box height, 10 cm
- Product box width, 26.6 cm
- Gross weight, 2.90 kg
