Cutting
Premium metal cutting wheel DREMEL® MAX EZ SPEEDCLIC (SC456DM)
Cutting
Dremel Max Cutting Wheel to make cuts in hard metals
  • Cutting wheel with maximum durability and lasting performance for demanding cutting jobs that require precision
  • Coated with Cubic Boron Nitride (CBN), an abrasive grit allowing the wheel to remain in shape and stay cool without shrinking
  • Designed with the EZ SpeedClic system making accessory changes quick and easy
See all variations
26 GBP
Metal pipes
Sheet Metal
Drywall/Plasterboard
Aerated Concrete
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
The heavy-duty Dremel Max Premium Cutting Wheel SC456DM is is coated with super abrasive grit called cubic boron nitride (CBN) which provides maximum durability allowing the wheel to remain sharp longer, stay cool, and prevent shrinking. The Max Premium Metal Cutting Wheel lasts 20 times longer than the regular 426 Cutting Wheels and is reinforced with a metal core to prevent breaking.
What can you do with it?
The high-performance cutting wheel features a 38.1 mm diameter and 1 mm thick blade making it ideal for cutting a variety of materials including stainless steel, nails, rebar, metal studs, threaded rod, copper, conduit, metal HVAC ducts, metal door jambs, and galvanized strut. The SC456DM is designed with the patented EZ SpeedClic system making accessory changes quick and easy.
How to use:
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately). Make cuts with the edge of the cutting wheel. We recommend using a (two-handed) golf grip while cutting. Let the accessory do the work without putting too much pressure on it or exceeding the maximum RPM to have the accessory last as long as possible. Are you in need to cut in a tight and awkward spaces? Use the Dremel 575 Right Angle Attachment to get into these hard-to-reach places.
Materials to use on
The SC456DM Cutting Wheel can be used on different metal types, like aluminum, copper, cast iron or even hardened steel.
Recommended speed (RPM):
Aluminium 35000 Brass 35000 Copper 35000 Steel 35000
Working diameter
Package contents
Price
2615S456DM
38.0 mm
1 piece
£25.50*
  • Dremel Max Cutting Wheel to make cuts in hard metals
2615S456JD
38.0 mm
12 pieces
£21.50*
DREMEL® EZ SpeedClic: Metal Cutting Wheels 12-Pack. (SC456B) 12 pieces
  • Reinforced for durability, make cuts in e.g. hardened steel
2615S476JB
38.0 mm
5 pieces
£14.50*
DREMEL® EZ SpeedClic: Plastic Cutting Wheels. (SC476) 5 pieces
  • For making straight cuts and slots in plastics
2615S409JB
38.0 mm
5 pieces
£15.50*
DREMEL® EZ SpeedClic: Thin Cutting Wheels. (SC409) 5 pieces
  • Extra thin cutting wheel. For making cuts in sheet metal and aluminium
Shank diameter
3.2 mm
Working diameter
38.0 mm
Max working depth
14.0 mm
32.0 mm
Maximum RPM
35,000 1/min
32.0 mm
Height
1.0 mm
8710364082810
2615S456DM
A SC456DM cutting accessory on a white background
Delivery details
  • 1x Dremel® Max EZ Speedclic Premium Cutting Wheel (SC456DM)
  • Product box length, 2 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
26 GBP
