Cutting
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Plastic Cutting Wheels. (SC476) 5 pieces
Cutting
For making straight cuts and slots in plastics
- The first cut-off wheel designed specifically for cutting plastic
- Designed with the patented EZ Speedclic™ system making accessory changes 6X faster than using a standard mandrel.
- 2X more cuts
Aerated Concrete
Drywall/Plasterboard
Plastic
Plexiglass
What can you do with it?
The SC476 is a reinforced cut-off wheel ideal for making clean cuts in plastics.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 sold separately).
Cutting wheels only work on their edge. Plastic can melt at high RPM, so we recommend to start at low RPM and not exceed the RPM limit of 15.000 RPM.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure.
Materials to use on
Plastic materials, like vinyl and plexiglass
Recommended speed
10.000 – 15.000 RPM
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
