SC456 metal cutting wheel (SC456-1)
NOT SELLABLE
Cutting
NOT SELLABLE
Cutting
Reinforced for durability, make cuts in e.g. hardened steel
  • Designed with the patented EZ Speedclic™ system making accessory changes 6X faster than using a standard mandrel.
  • 2X more cuts
  • Ideal for slicing, cutting, grooving, and trimming a variety of materials including hard metals like steel, metal pipes or sheet metal
See all variations
Metal pipes
Sheet Metal
Drywall/Plasterboard
Aerated Concrete
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
For slicing and cutting metal including hardened steel. Ideal for cutting, grooving and trimming all kinds of metal. Cut-off wheels make it easy to cut bolts or screws or make slots in rusted or stripped bolts and screws for removal with a screwdriver. Reinforced with fiberglass for increased durability. The SC409 wheels have a thickness of just 0.75 mm for even thinner cuts.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE
Cutting wheel
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron or even hardened steel.
Recommended speed
Aluminium 35000 Brass 35000 Copper 35000 Steel 35000
Working diameter
Package contents
F013000000
38.0 mm
1 piece
  • Reinforced for durability, make cuts in e.g. hardened steel
2615S545DM
38.0 mm
1 piece
Diamond cutting wheel DREMEL® MAX EZ SPEEDCLIC ( SC545DM)
  • Diamond cutting wheel for smooth, fine cuts in hard materials
2615S456DM
38.0 mm
1 piece
Premium metal cutting wheel DREMEL® MAX EZ SPEEDCLIC (SC456DM)
  • Dremel Max Cutting Wheel to make cuts in hard metals
Shank diameter
3.2 mm
Working diameter
38.0 mm
Max working depth
14.0 mm
Maximum RPM
35,000 1/min
0000000000000
F013000000
Dremel cutting accessory 38mm with EZ SpeedClic
