Retired Products
DREMEL® Pet Nail Grooming Kit (7020-PGK)
Retired Products
Safe and quiet pet nail grinder
  • Cutting nails is an essential part of pet grooming. Regularly trim your pet’s nails from the comfort of your home.
  • Make the nail trimming experience for your pet stress-free.
  • By gradually grinding the nails at a 45⁰ angle, you are in full control, making the trimming comfortable for you and your pet.
43 GBP
Cutting dogs nails is an important part of dog grooming. The Dremel 7020 tool is a dog nail grinder that allows you to gently and easily trim your pets’ nails at home, where they are most comfortable. By gradually sanding the nail at a 45⁰ angle, you are in full control while trimming your pets’ nails. It will prevent bleeding from cutting the nail too short, making the process safer and smoother than with nail clippers. The quiet motor makes the nail trimming experience for your pet stress free. The safety guard on the top of the tool covers all rotating parts, making the cutting experience just as comfortable for you. The transparent paw guide captures the nail dust, keeping the environment clean. Start nail grooming with the Dremel 7020 PGK for safe dog nail care. Also suitable for cats. The kit comes with interchangeable sanding disc accessories.
The covered attachment keeps all rotating parts away from your pet to ensure maximum safety during use
The quiet motor ensures that your pet does not become alarmed during the trimming process
Without the cords you can use the tool with maximum manoeuvrability even when your pet won’t sit still
Battery voltage
6.0 V
Weight
0.270 kg
20 cm
Depth
No load speed
7.000 - 18.000 1/min
Battery technology
No load speed (3)
Speed setting
Two speeds
Accessory quick change system
No
Sound pressure
- 0 dB(A)
Vibration
8710364080502
F0137020JA
User Manuals
A Pet Grooming Tool with a SC402 and 4 SD60-PGK accessories on a white background.
Delivery details
  • Pet nail grooming tool
  • EZ SpeedClic Mandrel and 4 EZ SpeedClic Sanding Discs
  • Product box length, 11.5 cm
  • Product box height, 21.1 cm
  • Product box width, 6.7 cm
43 GBP
