Saws
DREMEL® Moto-Saw (MS20-1/5)
Saws
Compact scroll saw with detachable fretsaw – Make detailed cuts easily
- Detachable coping function for handheld use to take the tool to the work piece
- Auto tensioning quick change™ mechanism for easy accessory change and optimal blade tensioning
- Variable speed control for optimal cutting in a variety of materials
The Dremel Moto-Saw is a compact and easy-to-use scroll saw for making detailed cuts in different materials. With its range of different saw blades, the Dremel Moto-Saw can handle many different materials easily. Thanks to its detachable fretsaw, it can be used not only stationary but in-hand anywhere. This user-friendly scroll saw is not only easy to store and set-up, but also easy to operate. The Dremel Moto-Saw is the most user-friendly scroll saw.
User Manuals
- Dremel Moto-Saw
- 2x General Purpose Wood Cutting Saw Blade (MS51)
- 2x Fine Wood Cutting Saw Blade (MS52)
- 1 x Metal Cutting Saw Blade (MS53)
- Parallel Guide attachment
- Instruction manual
- Sturdy and spacious storage case
- Product box length, 37.4 cm
- Product box height, 46.8 cm
- Product box width, 12.2 cm
- Gross weight, 4.72 kg
