Sanding
Sanding Disc 180 grit (411)
For (smooth) flat and edge sanding of soft materials such as wood or rust removal
What can you do with it?
Common uses for the Dremel sanding disc include smoothing and shaping wood or removing paint. is great for (smooth) flat and edge sanding of soft materials such as wood and fiberglass Dremel sanding discs have a finer grit than Dremel sanding bands. Also used for rust removal
The lower the grit, the more material removal.
The SC411 (grit: 60) and SC413 (grit: 240) are from the Dremel Exclusive EZ Speedclic family. This makes accessory changes easy as PULL - TWIST - RELEASE.
How to use?
These discs are best used with the Dremel tool facing towards the work piece, and are flexible to accommodate for any curves on the project. We recommend using mainly the center of the disc for maximum results.
Sanding discs will wear out and are replaceable by removing the mandrel.
Materials to use on
These disks can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel.
Can shape rubber surfaces
Recommended speed
Hardwood 10-35000
Softwood 10-35000
Aluminium 35000
Brass 35000
Copper 25-35000
Plastic 10-20000
Softwood 10-35000
Aluminium 35000
Brass 35000
Copper 25-35000
Plastic 10-20000
Technical details for Sanding Disc 180 grit (411)
Sandwich material
Steel-general
Metal pipes
Veneered woods
Plastic
Brass
Copper
Softwood
Soft Metal
Fiberboard
Laminates
Plywood
Hardwood
Chipboard
Technical specifications
Shank diameter
Working diameter
19,0 mm
Grit
180
Maximum RPM
20.000 1/min
Package Contents
36 pieces
Suitable Dremel devices
Multi-Tools
Retired Products
2615041132
8710364008421
Delivery details: Sanding Disc 180 grit (411)
Product box length, 1.8 cm
Product box height, 10 cm
Product box width, 5 cm
2615041132
8710364008421
8710364008421
