Heavy Duty Flex-Shaft
DREMEL® Fortiflex (9100-21)
Heavy duty flexible shaft – Work precisely for extended periods of time with complete control over your stationary projects
  • Powerful (300W) motor provides high torque at low speeds
  • Precision hand piece is engineered for control and comfort even with extended use
  • Heavy duty flexible shaft includes a patented bearing system for durability and cool operation
300 GBP
The Dremel Fortiflex is a high quality precision tool, consisting of a powerful hanging motor (300W), a patented heavy duty flexible shaft, an exchangeable precision hand piece and a foot pedal for variable speed control (0-20.000rpm). This makes it the ideal tool for stationary projects, like woodworking, jewellery making, stone working, car restoration, or any project where a combination of power and precision is required. The Dremel Fortiflex: power meets precision.
Rated power input
300 W
Voltage
Weight
1,50 kg
133 cm
8.5 cm
Depth
7 cm
No load speed
0 - 20.000 1/min
Battery technology
No load speed (3)
Sound pressure
79 dB(A)
Sound power
90 dB(A)
Vibration
6,3 m/s²
8710364046935
F0139100JB
User Manuals
Dremel Fortiflex 9100 attachment with accessories
Delivery details
  • Dremel Fortiflex motor
  • Heavy Duty Flex Shaft
  • Hand piece (9102)
  • Foot pedal
  • 21 high quality Dremel accessories
  • Hanging hook
  • Instruction manual
  • Product box length, 37.2 cm
  • Product box height, 27.3 cm
  • Product box width, 10 cm
  • Gross weight, 3,39 kg
300 GBP
