Corded Tools
DREMEL® Moto-Saw (MS20-1/5)
Compact scroll saw with detachable fretsaw – Make detailed cuts easily
Detachable coping function for handheld use to take the tool to the work piece
Auto tensioning quick change™ mechanism for easy accessory change and optimal blade tensioning
Variable speed control for optimal cutting in a variety of materials
Fast clamp base attaches to various tables, benches and surfaces
£109.00*
RRP incl. VAT
The Dremel Moto-Saw is a compact and easy-to-use scroll saw for making detailed cuts in different materials. With its range of different saw blades, the Dremel Moto-Saw can handle many different materials easily. Thanks to its detachable fretsaw, it can be used not only stationary but in-hand anywhere. This user-friendly scroll saw is not only easy to store and set-up, but also easy to operate. The Dremel Moto-Saw is the most user-friendly scroll saw.
Example of usage
Technical details for DREMEL® Moto-Saw (MS20-1/5)
Technical specifications
Rated power input
70 W
Voltage
Weight
1,10 kg
40 cm
21 cm
Depth
37 cm
No load speed
1.500 - 2.250 1/min
Battery technology
Cutting depth
18 mm
No load speed (3)
Accessory quick change system
Accessory Quick Change Lever
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
77,3 dB(A)
Sound power
88,3 dB(A)
Vibration
Capabilities
null
Included Accessories (5)
Delivery details: DREMEL® Moto-Saw (MS20-1/5)
Dremel Moto-Saw
2x General Purpose Wood Cutting Saw Blade (MS51)
2x Fine Wood Cutting Saw Blade (MS52)
1 x Metal Cutting Saw Blade (MS53)
Parallel Guide attachment
Instruction manual
Sturdy and spacious storage case
Product box length, 37.4 cm
Product box height, 46.8 cm
Product box width, 12.2 cm
Gross weight, 4,72 kg
F013MS20JB
8710364062782
8710364062782
