Corded Tools
DREMEL® Multi-Max MM20 (MM20-1/9)
Oscillating tool – Runs cool and smooth when remodeling, repairing and restoring your home
For this tool the following kit execution is available:
Technical details for DREMEL® Multi-Max MM20 (MM20-1/9)
Technical specifications
Rated power input
250 W
Voltage
Weight
1,35 kg
24 cm
No load speed
10.000 - 21.000 1/min
No load speed (3)
Oscillating Angle
L / R 1.5 °
Speed setting
Fully Variable
Accessory quick change system
No
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
74 - 78 dB(A)
Sound power
85 - 89 dB(A)
Vibration
2,5 - 5,2 m/s²
Delivery details: DREMEL® Multi-Max MM20 (MM20-1/9)
Dremel Multi-Max MM20
1x Hook and Loop Sanding Pad (MM11)
6x Sanding Paper (3x MM70P, 3x MM70W)
1x Wood Flush Cut Blade (MM480)
1x Wood & Metal Flush Cut Blade (MM482)
Vacuum cleaner attachment
Sturdy and spacious storage case
Product box length, 39.2 cm
Product box height, 26.6 cm
Product box width, 9.8 cm
Gross weight, 2,86 kg
F013MM20JB
8710364063734
Recommended products:
DREMEL® Moto-Saw
£109.00* RRP incl. VAT
DREMEL® Fortiflex
£280.00* RRP incl. VAT
DREMEL® DSM20
£135.00* RRP incl. VAT
Manuals
Download User manual
