Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Retired Products
High Speed Cutter (191)
Retired Products
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Veneered woods
Softwood
Leather
Plywood
Laminates
Chipboard
Brick
Drywall/Plasterboard
Aerated Concrete
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
What can you do with it?
High Speed Cutters work well for material removal in applications like shaping, carving, engraving, hollowing, grooving, slotting, inlaying making tapered holes or freehand routing. Tip: see the icon image or video for the result in the material.
How to use?
Use the sides of the head for an effective result. Most used grip for this accessory is the pencil grip. A less aggressive, more frequent pass will always produce better results than pushing too hard or forcing the tool through the material Use it at an angle less than 90' Advised Attachment: FLEXIBLE SHAFT (225); FLEX-SHAFT TOOL HOLDER (2222); DETAILER'S GRIP ATTACHMENT (577); MULTI-VISE (2500)
Materials to use on
This accessory works best on softer materials like wood, plastic and soft metals such as aluminum, copper, and brass. See the extensive List of materials in the images below
Recommended speed
Aluminium 15-25.000 Brass 15-25.000 Copper 15-25.000 Hardwood 20-30.000 Softwood 20-30.000 Plastic 15-20.000 Steel 15-20.000
Shank diameter
Working diameter
4.8 mm
Maximum RPM
30,000 1/min
Suitable Dremel devices
Multi-Tools
Retired Products
8710364007974
2615019132
Dremel accessory  192_High Speed Cutter 4,8 mm
Delivery details
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
