Collets / Mandrels / Miscellaneous
Dremel (LM1)
The light module allows a user for better and more precise work by enlightening the desired area.
Easily screw the LED Light Module (LM1) on your Dremel Multi-Tool
Enlighten difficult corners and dark areas with the fully adjustable 360° LED light
Work with greatest precision with clear visibility on your project
£15.40*
RRP incl. VAT
What can you do with it?
Easily screw the LED Light Module (LM1) on your Dremel Multi-Tool. With a fully adjustable 360° LED light you can complete your tasks in those difficult corners and dark areas with full visibility. The Light Module allows you to clearly see everything that you’re doing, so you can work with the greatest precision.
How to use?
Unscrew the regular Nose Cap from your Dremel Multi-Tool. Easily screw the Light Module with the included Nose Cap back on the tool. Switch on and switch off the LED light by clicking the on/off switch.
Example of usage
Technical details for Light Module (LM1)
Technical specifications
Accessory length
30,0 mm
25,0 mm
Height
35,0 mm
Delivery details: Light Module (LM1)
Light module
Nose cap
Product box length, 3 cm
Product box height, 10 cm
Product box width, 5 cm
26150LM1JA
8710364082827
8710364082827
