Multi-Tools
DREMEL® 4250 (4250-6/128)
Multi-Tools
Unlimited power, ultimate experience
- The highest performing corded Multi-Tool to tackle high-duty projects and tough applications for unlimited period of time.
- Most inclusive Dremel 4250 kit; 128 accessories and 6 attachments will allow you to unlock the full Dremel experience
- Bring precision to your toughest jobs and ease to your creative projects.
Dremel® 4250 gives you ultimate experience with unlimited power. Cut, carve, sand, grind, polish, engrave and do much more with this most exclusive kit of Dremel 4250. It includes 128 accessories and 6 attachments for all kinds off applications and DIY projects. Sturdy storage case will allow you to carry your tool easily and keep all accessories and attachments neatly. From the toughest functional jobs to detailed creative projects, this kit will support you across a broad range of applications.
Experience maximum corded power of the 175W motor allowing you to work on your heavy-duty DIY projects that require precision.
Compatible with all Dremel accessories which can be switched quickly and easily thanks to the EZ Twist nose caps integrated wrench.
With its intuitive button placement and rubber soft grip you will be in total control over your demanding projects.
