Corded Tools
DREMEL® Fortiflex (9100-21)
DREMEL® Fortiflex
DREMEL® Fortiflex
Heavy duty flexible shaft – Work precisely for extended periods of time with complete control over your stationary projects
  • Powerful (300W) motor provides high torque at low speeds
  • Precision hand piece is engineered for control and comfort even with extended use
  • Heavy duty flexible shaft includes a patented bearing system for durability and cool operation
  • Variable speed foot pedal allows you to match the speed with the application, hands-free
  • Interchangeable hand piece is compatible with other flex shaft tools
  • Can be used with all Dremel Multi-Tool accessories
£280.00* RRP incl. VAT
The Dremel Fortiflex is a high quality precision tool, consisting of a powerful hanging motor (300W), a patented heavy duty flexible shaft, an exchangeable precision hand piece and a foot pedal for variable speed control (0-20.000rpm). This makes it the ideal tool for stationary projects, like woodworking, jewellery making, stone working, car restoration, or any project where a combination of power and precision is required. The Dremel Fortiflex: power meets precision.
Example of usage
Technical details for DREMEL® Fortiflex (9100-21)
Technical specifications
Rated power input
300 W
Voltage
Weight
1,50 kg
133 cm
8.5 cm
Depth
7 cm
No load speed
0 - 20.000 1/min
Battery technology
No load speed (3)
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
79 dB(A)
Sound power
90 dB(A)
Vibration
6,3 m/s²
Delivery details: DREMEL® Fortiflex (9100-21)
Dremel Fortiflex motor
Heavy Duty Flex Shaft
Hand piece (9102)
Foot pedal
21 high quality Dremel accessories
Hanging hook
Instruction manual
Product box length, 37.2 cm
Product box height, 27.3 cm
Product box width, 10 cm
Gross weight, 3,39 kg
F0139100JB
8710364046935
Recommended products:
DREMEL® 4000 Platinum Edition
£210.00* RRP incl. VAT
Manuals
Download User manual
