Sanding
Sanding Band & Mandrel 6,4 mm 60 grit (430-2) 2 pieces
Sanding
Small sanding mandrel and sanding band (Grit P60)
  • Ideal for rough shaping and smoothing of wood and fiberglass
  • Perfect for removing rust from metal surfaces
  • Can be used to shape rubber surfaces
See all variations
8.3 GBP
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
What can you do with it?
Sanding bands will generally remove finish and material (wood or other soft material). These bands are also used for (rough) shaping and smoothing or rust removal from metal. If you want to remove just finish, consider something less aggressive like a flap wheel (no. 502 or 504), or a buff like the no. 511S/512S or 511E/512E.
How to use?
The physical appearance of the band indicates what grit it is, the larger the bumps the lower the grit.
Sanding bands are available in 120 and 60 grit. The lower the grit, the more material is removed.
Use the sides of the bands to do the sanding.
Sanding bands will wear out and are replaceable by loosening the screw on the top of the drum or using the DREMEL exclusive EZ Speedclic sanding drum, for even faster band replacement.
Materials to use on
These bands can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 15-25.000 Softwood 15-25.000 Aluminium 15-25.000 Brass 15-25.000 Ceramic 15-25.000 Copper 15-25.000 Plastic 15-25.000 Stone 15-25.000 Shell 15-25.000 Steel 15-25.000
Shank diameter
Working diameter
Grit
Package contents
Price
26150430JA
3.2 mm
6.4 mm
2 pieces
£8.00*
  • Small sanding mandrel and sanding band (Grit P60)
2615040732
3.2 mm
13.0 mm
1 piece
£3.70*
Sanding Band & Mandrel 13 mm grit 60 (407)
  • For (painted) material removal / shaping of wood and plastics.
2615040832
3.2 mm
13.0 mm
6 pieces
£3.20*
Sanding Band 13 mm 60 grit (408) 6 pieces
  • Large sanding band for sanding of wood and plastics
26150408DM
3.2 mm
13.0 mm
1 piece
£21.50*
Sanding band and hole drill DREMEL® MAX (408DM)
  • Sanding hard & soft woods, composites, fiberglass, Masonite boards, rigid foam, and more. Drilling soft wood and ceramic wall tile.
2615043132
3.2 mm
6.4 mm
6 pieces
£3.20*
Sanding Band 6,4 mm 60 grit (431) 6 pieces
  • Small sanding band for detailed sanding of wood and plastics
2615043232
3.2 mm
13.0 mm
6 pieces
£3.20*
Sanding Band 13 mm 120 grit (432) 6 pieces
2615043832
3.2 mm
6.4 mm
6 pieces
£3.20*
Sanding Band 6,4 mm 120 grit (438) 6 pieces
26150770JA
3.2 mm
6.4 mm
1 piece
£22.00*
DREMEL® 770B-02 (770B-02)
  • Versatile sanding band kit for shaping, smoothing, and rust removal.
26150771JA
3.2 mm
13.0 mm
1 piece
£22.00*
Sanding Band Variety Kit 13mm (771B02)
  • Comprehensive sanding band set for shaping, smoothing, and surface prep.
Shank diameter
3.2 mm
Working diameter
6.4 mm
Accessory length
36.0 mm
Aluminum Oxide
Shape
Band
Mandrel use
Use with 430 Sanding Mandrel
Grit
60
6.0 mm
Maximum RPM
35,000 1/min
6.0
Height
32.0
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364045167
26150430JA
Two cylindrical sanding drum attachments for a rotary tool on a white background.
Delivery details
  • 2 pcs
  • Product box length, 1.8 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
8.3 GBP
