Carving / Engraving
Diamond Wheel Point 2 mm (7103-2) 2 pieces
Carving / Engraving
Smallest ball shaped diamond bit, for engraving in hard material
- Bit is covered with diamond particles, making it ideal for quick and easy material removal
- Works well for fine, detailed work in wood, jade, ceramic, glass, hardened steel, semi-precious stones, and other hard materials
- The ball shape of the diamond coated wheel point can be used to make concave cuts or to hollow out material, while the tip makes round bottom slots, grooves, and rounded side cuts
See all variations
17.5 GBP
Carbon
Leather
Rubber
Plastic
Brick
Soft Metal
Softwood
Hardwood
Glass
Copper
Silver
Gold
Brass
Ceramic
Porcelain
Shank diameter
Working diameter
Accessory length
Package contents
Price
26157103JA
2.0 mm
45.0 mm
2 pieces
£17.00*
- Smallest ball shaped diamond bit, for engraving in hard material
Order number26157103JA
EAN-Code8710364044832
26157122JA
2.4 mm
46.0 mm
2 pieces
£15.00*
Diamond Wheel Point 2,4 mm (7122-2) 2 pieces
- Small cylindrical shaped diamond bit, for engraving in hard materials
Order number26157122JA
EAN-Code8710364044856
26157134JA
2.0 mm
46.0 mm
2 pieces
£17.00*
Diamond Wheel Point 2,0 mm (7134-2) 2 pieces
- Thin flat head diamond bit, for detailed engraving in hard materials
Order number26157134JA
EAN-Code8710364044863
26157105JA
4.4 mm
46.0 mm
2 pieces
£24.50*
Diamond Wheel Point 4,4 mm (7105-2) 2 pieces
- Biggest ball shaped diamond bit, for engraving in hard material
Order number26157105JA
EAN-Code8710364044849
Shank diameter
Working diameter
2.0 mm
Accessory length
45.0 mm
304 Stainless Steel
Shape
Ball
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
45.0 mm
Maximum RPM
25,000 1/min
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044832
26157103JA
EAN Code8710364044832
Delivery details- 2 pcs
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
17.5 GBP
