Grinding / Sharpening
Silicon Carbide Grinding Stone 4,8 mm (84922) 3 pieces
Small, cone shaped silicon carbide grinding stone.
  • Ideal for sharpening, deburring and general purpose grinding on harder materials
  • Designed to work well on stone, glass, ceramic, porcelain, gemstones and non-ferrous metals
  • Great for grinding and etching
10.5 GBP
Aerated Concrete
Concrete
Drywall/Plasterboard
Brass
Copper
Soft Metal
Porcelain
Brick
Marble
Granite
Ceramic
Glass
What can you do with it?
For sharpening, deburring and general purpose grinding. Typical uses include removal of stilt marks and excess glaze, sharp edges on tiles and engraving on glass. These grinding stones are tougher than aluminum oxide points, these are made especially for use on hard materials such as glass and ceramics.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
To grind and etch stone, glass, ceramics, porcelain and non-ferrous metals
Recommended speeds (RPM):
Ceramic: 20-30.000 Glass: 20-30.000 Stone: 20.000 - 25.000 Shell: 20.000 - 25.000
Package contents
Price
26154922JA
3 pieces
£10.50*
  • Small, cone shaped silicon carbide grinding stone.
26155602JA
3 pieces
£9.50*
Silicon Carbide Grinding Stone (85602) 3 pieces
  • Thin, small grinding stone. For grinding non-ferrous materials like stone
26153322JA
3 pieces
£10.50*
Silicon Carbide Grinding Stone 3,2 mm (83322) 3 pieces
  • Small, bullet shaped, silicon carbide grinding stone.
2615542232
1 piece
£3.70*
Silicon Carbide Grinding Stone 19,8 mm (85422)
  • Thin grinding stone. For grinding non-ferrous materials like stone
Shank diameter
Working diameter
4,8 mm
Accessory length
40,0 mm
Silicon Carbide
Shape
Small Taper
Mandrel use
No Mandrel Needed
5,0 mm
5,0 mm
Height
Maximum RPM
25.000 1/min
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044955
26154922JA
Dremel  accessory 84922_Silicon Carbide Grinding Stone 4,8 mm (84922)
Delivery details
  • Product box length, 2 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
10.5 GBP
