Cordless Tools
Cordless craft multi-tool - Compact. Portable. Versatile.
Easily switch between applications within 1 or more DIY projects: engrave, carve, cut, polish, clean and sand
Compact size for portability and light in weight with prencil-grip for comfort
Tackle your creative DIY projects straight away with the 15 included accessories
Built-in LED lights gives you a clear sight of your work piece for better accuracy
The Dremel Micro is a cordless craft multi-tool with pencil grip for working on a variety of light-duty-DIY tasks with excellent comfort and precision. The included 15 accessories give you all versatility needed for small DIY projects: engraving, carving, etching, sanding, polishing and cleaning.
Example of usage
Technical details for DREMEL® Micro (8050-15)
Technical specifications
Battery voltage
7,2 V
Battery capacity
1,0 Ah
Charging time
3.75 h
Weight
0,250 kg
19.5 cm
3.5 cm
Depth
3.5 cm
No load speed
5.000 - 28.000 1/min
Battery technology
Lithium-Ion / ECP
No load speed (3)
Speed setting
Variable
Precision tip
Dual temperature
Removable cord
Drip control
Sound power
76 dB(A)
Vibration
9,8 m/s²
Included accessories (15)
Overview of prices and delivery details
Order number: F0138050HB
EAN Code: 8710364080861
£100.00
See delivery details
Dremel Micro
15 high quality Dremel accessories
3 hour 45 minute battery charger (docking station)
Quick start guide
Test materials
Product box length, 30.5 cm
Product box height, 16.5 cm
Product box width, 8.5 cm
Gross weight, 0,74 kg
Order number: F0138050JF
EAN Code: 8710364076857
£120.00
Dremel Micro
35 high quality Dremel accessories (including EZ SpeedClic accessories)
Compact storage case
Product box length, 22.1 cm
Product box height, 29.4 cm
Product box width, 8.1 cm
Gross weight, 0,99 kg
