Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Collets / Mandrels / Miscellaneous
Mandrel (401-3) 3 pieces
Mandrel tomount different cleaning and polishing accessories
  • Used primarily with Dremel 414, 422 & 429 felt polishing accessories
  • Simple and easy to use
  • Shank (3.2 mm) with a screw-like head used to hold polishing bits and accessories.
5.8 GBP
A simple and easy to use shank (3.2 mm) with a screw-like head used primarily to hold polishing bits and accessories. Used primarily with the 414, 422 & 429 felt polishing accessories.
Package contents
Price
26150401JA
3 pieces
£5.70*
  • Mandrel tomount different cleaning and polishing accessories
26150LM1JA
1 piece
£16.00*
Light Module (LM1)
  • The light module allows a user for better and more precise work by enlightening the desired area.
2615S402JB
1 piece
£14.50*
EZ SpeedClic Mandrel (SC402)
26150402JA
4 pieces
£9.60*
Mandrel (402-4) 4 pieces
  • Mandrel to mount different accessories to use with your Dremel Multi-Tool
Shank diameter
Accessory length
39.0 mm
Mandrel use
No Mandrel Needed
6.0 mm
Maximum RPM
35,000 1/min
6.0 mm
Height
32.0 mm
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364045068
26150401JA
3 pieces Dremel mandrel 401 to mount different accessories to use with your Dremel Multi-Tool
Delivery details
  • 3 pcs
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
5.8 GBP
