Cordless Tools
Easy-to-use. Versatile. Use anywhere.
Easily switch between applications within many DIY projects, whether its sanding, grinding, sharpening, carving, engraving, cleaning or polishing.
Take on multiple kinds of creative projects or light duty DIY projects with the 15 accessories included.
You’ll be ready for your next DIY-project anytime and any place with the cordless and USB-chargeable Dremel Lite.
With the included quick start guide and accessory information sheet, you have all the elements to create the perfect first experience.
£65.00*
RRP incl. VAT
The versatility of this kit allows you to sand, grind, sharpen, carve, engrave, clean and polish, with the only change being the accessory. Tackle any kind of light duty home improvement or creative project. The 15 accessories included gives you the freedom to work on multiple materials with multiple applications. You can use the cordless and USB-chargeable Dremel Lite anytime and anywhere, indoors or outdoors. Whether this will be your first Dremel Multi-Tool or an add on to your Dremel collection you can rely on this kit to complete your projects.
Example of usage
Technical details for DREMEL® Lite (7760-15)
Technical specifications
Battery voltage
3,6 V
Battery capacity
Charging time
2.75 h
Weight
0,270 kg
19.5 cm
Depth
No load speed
8.000 25.000 1/min
Battery technology
Speed setting
Fully Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Vibration
Included Accessories (15)
Delivery details: DREMEL® Lite (7760-15)
Dremel Lite
15 high quality Dremel accessories
2 hour 45 minutes charging plug and seperate USB cable
Quick start guide
Accessory information sheet
F0137760JB
8710364081400
8710364081400
