Cutting
Cutting Wheel 32mm (426) 5 pieces
Cutting
Reinforced for durability, make cuts in e.g. hardened steel
- Ideal for cutting, grooving and trimming all kinds of metal
- May also be used on other materials-including thin wood, plastics and ceramics
- Cut bolts or screws or make slots in rusted or stripped bolts and screws
Glass fibre reinforced plastics
Brick
Marble
Drywall/Plasterboard
Aerated Concrete
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
Plastic
What can you do with it?
Good for slicing, making straight cuts and slots in all kinds of metal, like hardened steel, sheets metal or aluminum. Easily cut bolts, or make slots in rusted and/or stripped bolts / screws for removal with a screwdriver.
How to use?
Use with 402 Mandrel: unscrew the top screw on the mandrel using the wrench, put the screw through the middle hole of the disk and screw it back on the mandrel.
If using the metal cutting wheels, cut on high speed – use light pressure. The wheels will last longer and cut faster if light pressure is used rather than heavy pressure and there is less risk of breaking it.
Since these disks are abrasive, the diameter of the wheel is going to wear away. If the wheel becomes too small to execute the cut, stop the cut and replace the wheel.
When using a cut-off wheel, we recommend using a two handed golf like grip to hold and guide the tool and go for a right angle. If you angle the wheel in the cut, the wheel will probably break.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron. But also for short cuts in plastic or brick. On materials like a galvanized metal (Ductwork) or hardened steel, it’s best to use reinforced cut-off wheel (426)
Recommended speed
Aluminium 25-35.000 Brass 25-35.000 Copper 25-35.000 Plastic 15-25000 Steel 25-35000
- Reinforced for durability, make cuts in e.g. hardened steel
Cut-Off Wheel 24 mm (409) 36 pieces
- For cutting in metals
Heavy Duty Cut-Off Wheel 24 mm (420) 20 pieces
- For tougher cutting in metals, like hardened steel
Cut-Off Wheel 32 mm (540-5) 5 pieces
- For straight cuts in metal
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 2 cm
- Product box height, 10 cm
- Product box width, 5 cm
