Multi-Tools
Multi-Tools
Keep the power, lose the cord
  • Enjoy the same power as with Dremel corded 4250.
  • Great run time and cooler operation to work comfortably for longer.
  • 12V, 2Ah battery so you can work anywhere.
155 GBP
Portable long-lasting power
Get the power to perform at your peak with the cordless Dremel 8240. With this portable powerhouse, you’re in control. You get the same power as with corded Dremel 4250, but without being tied to a socket. Small but mighty, you’ll enjoy a long runtime thanks to its powerful and removable 2Ah battery.
Designed with you in mind
Dremel 8240 is designed with you in mind. From the ergonomic tool design to the button placement, this portable multi-tool has it all. You’ll love our trademark Dremel look and feel, with its super easy set-up and logical layout. We’ve made it run cooler and with lower noise so you can focus all your attention on your project. Plus the soft grip fits you like a glove. The speed setting of the Dremel 8240 is in the middle, right where you place your thumb to hold the tool. Now that’s ergonomic design at your fingertips. Dremel 8240 also has a motor-brake which enables you to be more in control and safe. Rather than applying a slowing force, motor-brake stops the rotation immediately when turning the tool off. The LED battery life indicators show you at a glance the remaining battery charge level. Your Dremel 8240 includes a hanger bail so it’s easy to hang on your Dremel toolholder with your Dremel Flex-shaft.
Multi-tool for multiple applications
Power in action. Dremel 8240 is as versatile as it is powerful. Want to cut, grind, carve, engrave, sand, clean or polish? Whatever job you’ve got in mind, your Dremel 8240 is up for it as it’s compatible with the full range of Dremel multi-tool attachments and accessories. This includes the EZ SpeedClic with its revolutionary pull – click – twist mechanism that lets you change accessories six times faster. Plus you can use Dremel MAX accessories with your Dremel 8240. They set the standard when it comes to being long-lasting and durable.
A case for greater control, safety and detail
A wide range of accessories tailored to specific applications. It comes with a 12V, 2Ah battery and 2Ah Charger. The three included attachments – detailers grip, shaping platform and shield attachment – give you optimum control, safety and detail. With a 45-piece accessory set, including EZ SpeedClic, you’ll have the right accessory for more jobs than ever. This all comes in an attractive canvas fabric tool bag with straps for holding everything in place and a handy compartment for storing the manual and other information.
Battery indicator for convenient level visibility.
A hanger bail that lets you hang on your Dremel toolholder with your Dremel Flex-Shaft.
Compatible with your existing 12V battery - Dremel or Bosch Professional.
Battery voltage
12.0 V
Battery capacity
2.0 Ah
Charging time
1.05 h
Weight
0.660 kg
25.4 cm
5.4 cm
Depth
No load speed
5.000 35.000 1/min
Battery technology
Speed setting
Fully Variable Speed
Accessory quick change system
8710364082872
F0138240JG
User Manuals
Regulatory Information
Your Selection
Dremel 8240 with 5 accessories and the charger
Order number: F0138240JB
EAN Code: 8710364082841
120 GBP
Product details
Dremel 8240 Multi tool Platinum box  with 65 accessories and 5 attachments
Order number: F0138240JR
EAN Code: 8710364083398
215 GBP
Product details
