Retired Products
Retired Products
Multi-Tool – Cordless. Fast. Maximum power.
  • Save storage space. One tool for cutting, routing, grinding, sharpening, polishing, cleaning, carving and engraving
  • The Multi-Tool for the more demanding DIY’er
  • Free of any cords - you can take the tool anywhere, indoor and outdoor
137.79 GBP
This Dremel kit is the premium offer in the cordless Multi-Tool range. The high performance 8200 Li-ion cordless Multi-Tool with EZ Twist nose cap, comes in a practical carrying case which contains a 1-hour battery charger, the Shaping Platform attachment, allowing you to sand or grind perfectly at 90° and 45°, the Line & Circle Cutter attachment and 45 original Dremel accessories including EZ SpeedClic. With this supreme kit even the most demanding craftsman will be satisfied.
Battery voltage
10.8 V
Battery capacity
1.5 Ah
Charging time
1 h
Weight
0.620 kg
25 cm
Depth
6.5 cm
No load speed
5.000 - 33.000 1/min
Battery technology
Lithium-Ion / ECP
No load speed (3)
Speed setting
Variable
Accessory quick change system
Sound pressure
72 dB(A)
Sound power
83 dB(A)
Vibration
1,1 - 5,6 m/s²
8710364051779
F0138200JE
User Manuals
Your Selection
Dremel Multi-Tool 8200 with 1 attachment, 35 accessories in a plastic storage box and a fabric case
Order number: F0138200JB
EAN Code: 8710364051748
114.86 GBP
Product details
Dremel 8200 Platinum
DREMEL® 8200 Platinum Edition (8200-5/65)
Order number: F0138200KP
EAN Code: 8710364066261
196.54 GBP
Product details
Dremel 8200 with the box and 20 accessories
DREMEL® 8200 (8200-20)
Order number: F0138200JK
EAN Code: 8710364072125
158.32 GBP
Product details
