Drilling
DREMEL® Glass Drilling Bit (662)
Drilling
Thinnest glass drilling bit to be used on straight or curved material
  • Drill holes in both flat and contoured glass
  • Diamond-impregnated cutting bit for long life
  • Diamond grit around the circumference of the bit allows it to rasp a larger hole if needed
See all variations
20 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Glass
What can you do with it?
Ideal for drilling holes in both flat and contoured surfaces like glass or ceramic wall. Diamond grit is a full 360-degrees around the circumference of the bit which allows it to be used in a rasping action to enlarge a hole if needed. Holes on the side of the bit allow the removal of material. Ideal for decorative projects including glass blocks or bottles.
How to use?
When cutting a hole, ensure your work piece is well secured and do not apply excessive pressure to avoid cracking the glass. Apply cooling liquid or water to the material. Hold your tool at a 45 degree angle to go into the material. Then gradually lift your tool up to make a 90 degree drill. Apply drops of water / cooling liquid to the work piece for a clean drill operation. You can take the accessory out of the material to apply water or cooling liquid. Use with cordless tools only.
Materials to use on
Suitable for use on glass, ceramic wall tile, glass block, glass bottles, jewelry - flat or contoured surfaces.
Recommended speed
10.000-15.000 RPM
Shank diameter
WORKING_DIAMETER
Accessory length
Package contents
Price
26150662JB
3.2 mm
44.0 mm
1 piece
£19.50*
  • Thinnest glass drilling bit to be used on straight or curved material
26150663JB
44.0 mm
1 piece
£26.50*
DREMEL® Glass Drilling Bit (663)
  • Biggest glass drilling bit to be used on straight or curved material
Shank diameter
Working diameter
3.2 mm
Working length
5.0 mm
Accessory length
44.0 mm
Carbon Steel with Diamond Coating
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
45.0 mm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364080380
26150662JB
Dremel accessory  662 Glass Drilling Bit
Delivery details
  • The Dremel Glass Drilling Bit 662 is ideal for cutting holes in glass. You can drill perfect 3.2mm diameter holes. To be used with DREMEL cordless tools.
  • Product box length, 3.6 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
20 GBP
