Attachments to Cut
DREMEL® Wall & Floor Grout Removal Kit (568)
Attachments to Cut
Remove grout in between your tiles while having total control and precision
  • Safely and quickly remove grout using your Dremel Multi-Tool with a minimised risk of chipping or damaging your tiles when compared to traditional methods.
  • The guides fixed 30° angle to ensure accurate and controlled removal of grout.
  • Never lose sight of your grout line from the large windows in the guide giving you more confidence and safety.
21.6 GBP
What can you do with it?
Remove grout from the palm of your hand with ease and accuracy using your Dremel Multi-Tool and the Wall & Floor Grout Removal Kit (568). The 30 degree cutting angle of the provided guide gives you sturdy and controlled cuts which enables you to easily follow and remove the grout line, minimizing the risk of breaking a tile or damaging the surface you work on. The two included and different sized Grout Removal Bits (569 and 570) let's you tackle different thicknesses of grout lines.
How to use?
"Remove your Dremel Multi-Tool nose cap, insert and tighten your chosen accessory, screw on the cutting guide and adjust up to 13mm of depth. Always use both hands to pull your Dremel Multi-Tool along the grout line, using the large windows to have a ultimate view on your cut for clean grout removal with maximum safety.
Package contents
Price
26150568JB
1 piece
£21.00*
  • Remove grout in between your tiles while having total control and precision
26150565JB
1 piece
£16.50*
DREMEL® Multipurpose Cutting Kit (565)
  • Cut out any shape in a variety of materials while having full control
26150566JB
1 piece
£20.50*
DREMEL® Wall Tile Cutting Kit (566)
  • Make controlled cuts in any shape in wall tiles
26150678JB
1 piece
£19.00*
DREMEL® Line & Circle Cutter (678)
  • Cut perfect holes and straight cuts with your Dremel Multi-Tool
Working length
19.0 mm
5.5 cm
Depth
7.5 cm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364082414
26150568JB
User Manuals
Dremel Wall and floor grout removal kit
Delivery details
  • Angled Cutting Guide
  • 1.6 mm Grout Removal Bit 569
  • Product box length, 9 cm
  • Product box height, 12 cm
  • Product box width, 6 cm
21.6 GBP
