Grout Removal
Grout Removal Bits 1,6 mm (569)
Grout Removal
Tip is generally less than the distance between wall tiles
- Easily remove both wall and floor grout
- A high-speed cutter
- 30 degree angle for controlled grout removal
Drywall/Plasterboard
Aerated Concrete
What can you do with it?
This bit is used to remove the grout between tiles in e.g. Bathrooms or toilets. Ideal for replacing wall and floor grout or removing grout to replace broken tiles.
The 569 grout bit tip is generally less than the distance between wall tiles (diameter of head: 1,6 mm). The 570 is designed to get through floor grout (diameter of head: 3.2mm).
These bits are designed for small repair jobs. If you have a large removal requirement, you may need multiple bits to get through all of the grout.
How to use?
Use with the Dremel Grout Removal Attachment (model 568).
The angled attachment is designed so the bit is pulled gently through the grout – never pushed. Pushing will ruin the bit. There are two guide points on the attachment that will help keep the bit between the tiles
Use caution to avoid the bit touching the tile. This accessory is a solid carbide tip and it will nick the tile if it comes in contact with it while the tool is turned on.
A slow feed rate through the grout is recommended with some attention in older homes to the metal spacers that may still remain in the grout being removed.
To remove a greater depth of grout, start by removing the surface grout. Then adjust the guide to a greater depth and take a second pass.
For corners you will need to remove the guide. Keep a steady hand and carefully pull the tool toward you.
Materials to use on
Grout
Recommended speed
15.000-20.000 RPM
- Tip is generally less than the distance between wall tiles
Grout Removal Bits 3,2 mm (570)
- For removal of grout on floor tiles
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.5 cm
- Product box height, 10 cm
- Product box width, 5 cm
