Attachments to Cut
Dremel (568)
DREMEL® Wall & Floor Grout Removal Kit
Remove grout in between your tiles while having total control and precision
  • Safely and quickly remove grout using your Dremel Multi-Tool with a minimised risk of chipping or damaging your tiles when compared to traditional methods.
  • The guides fixed 30° angle to ensure accurate and controlled removal of grout.
  • Never lose sight of your grout line from the large windows in the guide giving you more confidence and safety.
  • Adjust the depth to up to 13mm to suit different grout lines you have to tackle
  • Contents: 1x Grout removal guide, 1x Grout removal accessory (569)
£20.60* RRP incl. VAT
What can you do with it?
Remove grout from the palm of your hand with ease and accuracy using your Dremel Multi-Tool and the Wall & Floor Grout Removal Kit (568). The 30 degree cutting angle of the provided guide gives you sturdy and controlled cuts which enables you to easily follow and remove the grout line, minimizing the risk of breaking a tile or damaging the surface you work on. The two included and different sized Grout Removal Bits (569 and 570) let's you tackle different thicknesses of grout lines.
How to use?
"Remove your Dremel Multi-Tool nose cap, insert and tighten your chosen accessory, screw on the cutting guide and adjust up to 13mm of depth.
Always use both hands to pull your Dremel Multi-Tool along the grout line, using the large windows to have a ultimate view on your cut for clean grout removal with maximum safety.
Example of usage
Technical details for DREMEL® Wall & Floor Grout Removal Kit (568)
Technical specifications
Working length
19,0 mm
5.5 cm
Depth
7.5 cm
Variations
Delivery details: DREMEL® Wall & Floor Grout Removal Kit (568)
Angled Cutting Guide
1.6 mm Grout Removal Bit 569
Product box length, 9 cm
Product box height, 12 cm
Product box width, 6 cm
26150568JB
8710364082414
Manuals
Download User manual
