Corded Tools
DREMEL® 4000 (4000-1/45X)
Dremel Advanced Kit
Work on a wide range of materials with this limited edition kit that has 20% added value.
Have maximum power and precision with the Dremel 4000 Multi-Tool that has the most variable rotary speed (5,000 – 35,000 RPM).
With the full set of 45 Dremel accessories you can easily go from cutting to grinding and from cleaning to sanding with just one Multi-Tool.
Take on any detailed project that requires total control with the included Detailer’s Grip Attachment.
Store and transport your kit with the sturdy toolbox, a tool holder and the easy storage solution for the accessories.
Master your DIY projects and take your skills to the next level with the Dremel Advanced Kit. The powerful Dremel 4000 Multi-Tool allows you to work better and faster on any kind of task. This versatile kit with 45 included accessories enables you to easily go from cutting to grinding to cleaning to polishing with just one Multi-Tool. Have total control over your project with the included Detailer’s Grip Attachment. Stay organised with the sturdy toolbox, a tool holder and an easy storage solution for the accessories. You can tackle any kind of DIY home improvement project with this versatile kit.
Example of usage
Technical details for DREMEL® 4000 (4000-1/45X)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 35.000 1/min
Battery technology
Speed setting
Fully Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
Included Accessories (35)
Overview of prices and Kit content
Order number: F0134000JE
EAN Code: 8710364048205
Dremel 4000
65 high quality Dremel accessories in Mini Accessory Case (including EZ SpeedClic starter set)
High quality Flex Shaft
Pencil grip nose cap
Line & Circle Cutter
Shaping Platform
Detailer’s Grip
Instruction manual
Spacious and sturdy storage case
Product box length, 26.8 cm
Product box height, 39 cm
Product box width, 10 cm
Gross weight, 2,70 kg
DREMEL® 4000 (4000-4/55)
Order number: F0134000UB
EAN Code: 8710364080694
DREMEL® 4000
57 high quality Dremel accessories
Flexshaft attachment (225)
Line & Circle Cutter attachment (678)
Cutting Guide attachment (565)
Detailer's Grip attachment (577)
Aluminum carry case
Accessory holder
Accessory information sheet
Instruction manual
Product box length, 23.3 cm
Product box height, 18.6 cm
Product box width, 36.5 cm
Gross weight, 3,40 kg
Order number: F0134000UN
EAN Code: 8710364081462
Dremel 4000
45 high quality Dremel accessories (including EZ SpeedClic starter set)
Detailers grip
Plastic toolholder
2x Accessory holder
Instruction manual
Plastic Tool case
