Routing
Router Bit (HSS) 8,0 mm (655)
Routing
See all variations
23 GBP
Veneered woods
Fiberboard
Chipboard
Laminates
Plywood
Softwood
Hardwood
Rubber
Plastic
Plexiglass
Carbon
Keyhole router bit.
For routing, mounting slots in picture frames or anything that needs to be hung.
Shank diameter
Working diameter
Accessory length
Package contents
Price
26150655JA
8.0 mm
37.0 mm
1 piece
£22.00*
- Biggest straight edge router bit. For routing in wood
Order number26150655JA
EAN-Code8710364023042
2615061232
9.5 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (612)
- For making a round edge to your wooden workpiece
Order number2615061232
EAN-Code8710364008254
2615061532
9.5 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (615)
Order number2615061532
EAN-Code8710364008285
2615064032
6.4 mm
37.0 mm
1 piece
£11.00*
Router Bit (HSS) 6,4 mm (640)
- For inlaying and routing a V groove in wood
Order number2615064032
EAN-Code8710364008308
2615065032
3.2 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 3,2 mm (650)
- Smallest straight edge router bit. For routing in wood
Order number2615065032
EAN-Code8710364007417
2615065232
4.8 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 4,8 mm (652)
- Second to smallest straight edge router bit. For routing in wood
Order number2615065232
EAN-Code8710364008315
2615065432
6.4 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 6,4 mm (654)
- Second to biggest straight edge router bit. For routing in wood
Order number2615065432
EAN-Code8710364008322
26150655JA
8.0 mm
37.0 mm
1 piece
£22.00*
26150660JA
1 piece
£46.00*
DREMEL® Multipurpose Router Bit Set (660)
- Set of 7 routing accessories to rout in a variety of materials
Order number26150660JA
EAN-Code8710364069972
Shank diameter
Working diameter
8.0 mm
Working length
2.7 mm
Accessory length
37.0 mm
Usage
Keyhole router bit
Maximum RPM
35,000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
8710364023042
26150655JA
EAN Code8710364023042
Delivery details- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
23 GBP
