Routing
Router Bit (HSS) 8,0 mm (655)
Router Bit (HSS) 8,0 mm Router Bit (HSS) 8,0 mm
Biggest straight edge router bit. For routing in wood
£19.00* RRP incl. VAT
Keyhole router bit.
For routing, mounting slots in picture frames or anything that needs to be hung.
Example of usage
Technical details for Router Bit (HSS) 8,0 mm (655)
  • Veneered woods Veneered woods
  • Fiberboard Fiberboard
  • Chipboard Chipboard
  • Laminates Laminates
  • Plywood Plywood
  • Softwood Softwood
  • Hardwood Hardwood
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Carbon Carbon
  • Attachment Attachment
Technical specifications
Shank diameter
Working diameter
8,0 mm
Working length
2,7 mm
Accessory length
37,0 mm
Usage
Keyhole router bit
Maximum RPM
Package Contents
1 piece
Variations
Delivery details: Router Bit (HSS) 8,0 mm (655)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
26150655JA
8710364023042
