Carving / Engraving
Dremel (117)
Carve and engrave in curved and straigh material like wood
£12.30*
RRP incl. VAT
What can you do with it?
High Speed Cutters work well for material removal in applications like shaping, carving, engraving, hollowing, grooving, slotting, inlaying making tapered holes or freehand routing. Tip: see the icon image or video for the result in the material.
How to use?
Use the sides of the head for an effective result.
Most used grip for this accessory is the pencil grip.
A less aggressive, more frequent pass will always produce better results than pushing too hard or forcing the tool through the material
Use it at an angle less than 90'
Advised Attachment: FLEXIBLE SHAFT (225); FLEX-SHAFT TOOL HOLDER (2222); DETAILER'S GRIP ATTACHMENT (577); MULTI-VISE (2500)
Materials to use on
This accessory works best on softer materials like wood, plastic and soft metals such as aluminum, copper, and brass. See the extensive List of materials in the images below
Recommended speed
Aluminium 30.000
Brass 30.000
Copper 30.000
Hardwood 35.000
Softwood 20-25.000
Plastic 35.000
Steel 20-25.000
Brass 30.000
Copper 30.000
Hardwood 35.000
Softwood 20-25.000
Plastic 35.000
Steel 20-25.000
Technical details for High Speed Cutter 6,4 mm (117)
- Veneered woods
- Softwood
- Leather
- Plywood
- Laminates
- Chipboard
- Brick
- Drywall/Plasterboard
- Aerated Concrete
- Hardwood
- Soft Metal
- Rubber
- Plastic
- Plexiglass
- Carbon
- RPM
Technical specifications
Shank diameter
Working diameter
Accessory length
High Speed Steel
Shape
Ball nose
Mandrel use
No Mandrel Needed
6,0 mm
6,0 mm
Height
Maximum RPM
30.000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
26150117JA
8710364044672
Delivery details: High Speed Cutter 6,4 mm (117)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1 cm
26150117JA
8710364044672
8710364044672
