Routing
Router Bit (HSS) 3,2 mm (650)
Routing
Smallest straight edge router bit. For routing in wood
  • Used for edging and grooving wood, Dremel router bits are ideal for routing, inlaying and mortising in wood and other soft materials
  • Straight router bits are flat on the bottom for cutting square grooves, rabbets and dadoes, and for leveling recessed areas
  • High-quality router bit
See all variations
11.2 GBP
Veneered woods
Fiberboard
Chipboard
Laminates
Plywood
Softwood
Hardwood
Rubber
Plastic
Plexiglass
Carbon
Straight Bits.
General purpose routing or grooving.
Shank diameter
Working diameter
Accessory length
Package contents
Price
2615065032
3.2 mm
36.0 mm
1 piece
£11.00*
  • Smallest straight edge router bit. For routing in wood
2615061232
9.5 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (612)
  • For making a round edge to your wooden workpiece
2615061532
9.5 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (615)
2615064032
6.4 mm
37.0 mm
1 piece
£11.00*
Router Bit (HSS) 6,4 mm (640)
  • For inlaying and routing a V groove in wood
2615065232
4.8 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 4,8 mm (652)
  • Second to smallest straight edge router bit. For routing in wood
2615065432
6.4 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 6,4 mm (654)
  • Second to biggest straight edge router bit. For routing in wood
26150655JA
8.0 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 8,0 mm (655)
  • Biggest straight edge router bit. For routing in wood
26150660JA
1 piece
£46.00*
DREMEL® Multipurpose Router Bit Set (660)
  • Set of 7 routing accessories to rout in a variety of materials
Shank diameter
Working diameter
3.2 mm
Working length
1.0 mm
Accessory length
36.0 mm
High Speed Steel
Mandrel use
No Mandrel Needed
Usage
Straight
3.0 mm
3.0 mm
Height
36.0 mm
Maximum RPM
35,000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
8710364007417
2615065032
Dremel accessory 650_Router Bit (HSS) 3,2 mm
Delivery details
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.3 cm
11.2 GBP
