Corded Tools
Multi-Tool – Powerful. Dynamic. Intuitive to use.
Maximize the room you have in your workshop: carve, engrave, rout, cut, sand, grind, sharpen, polish and clean with just one tool
Make your heavy duty precision projects easy
Fastest and most intuitive accessory changing with the integrated EZ Change system
Continuously find new projects to tackle with the 75 included accessories and 4 attachments.
2 year warranty
This kit includes the top of the line Dremel 4200 with EZ Change, the world's first accessory quick change system for Multi-Tools. Additionally, the kit includes 4 attachments and 75 original Dremel accessories. All this is packed in a neatly organised case that includes a removable accessory tray and a tool holder which can be fixed to the wall and allows for easy wrapping of the tool's cord.
Technical details for DREMEL® 4200 (4200-4/75 EZ)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
Depth
No load speed
5.000 33.000 1/min
Battery technology
Speed setting
Fully Variable
Accessory quick change system
EZ Change
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
74,4 dB(A)
Sound power
85,4 dB(A)
Vibration
18 ± 3,3 m/s²
Included Accessories (67)
Overview of prices and Kit content
Order number: F0134200JB
EAN Code: 8710364068289
Dremel 4200
75 high quality Dremel accessories
Cutting Guide attachment
Line & Circle Cutter
Shaping Platform attachment
Comfort Guard attachment
Spacious and sturdy storage case
Product box length, 26.8 cm
Product box height, 39 cm
Product box width, 10 cm
Gross weight, 2,44 kg
Order number: F0134200JF
EAN Code: 8710364074778
Dremel 4200
Cutting Guide attachment (565)
Line & Circle Cutter attachment (678)
Shaping Platform attachment (576)
Comfort Guard attachment (550)
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your project
Product box length, 27 cm
Product box height, 9.9 cm
Product box width, 39 cm
Gross weight, 2,51 kg
