Sanding
Flap wheel 4,8 mm (504)
Sanding
Smallest flap wheel (grit P80). Works well for (gentle) finish removal
  • Flapwheels grind and polish flat or contoured surfaces
  • Effective as finishing sander after heavy -surface sanding and material removal is complete
  • 80 grit for medium finish sanding
10 GBP
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
What can you do with it?
Flap wheels are great for finish removal and light material clean up because they are more forgiving than sanding bands. They won’t bite into the material as quickly. They also tend to run a little cooler because of the flaps – so they are less likely to put any burn into the material. Grind and polish flat or contoured surfaces. Most effective when used as a finishing sander after heavier surface sanding and material removal is completed. Comes in fine and coarse grades
How to use?
Flap wheels are most effective when the edge is flat against the work piece, allowing for the most abrasion to take place.
Materials to use on and recommended speed
Aluminium 20-25.000 Brass 20-25.000 Copper 20-25.000 Hardwood 20-25.000 Plastic 20-25.000 Softwood 20-25.000 Steel 20-25.000
Shank diameter
3.2 mm
Working diameter
4.8 mm
Accessory length
50.0 mm
Cloth-Reinforced with Aluminum Oxide Abrasive
Shape
Wheel
Mandrel use
No Mandrel Needed
Grit
80
30.0 mm
Maximum RPM
35,000 1/min
30.0
Height
44.0
Suitable Dremel devices
Retired Products
Multi-Tools
8710364015269
2615050432
Dremel accessory 504 FLAP WHEEL 4,8 MM
Delivery details
  • Product box length, 2.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
10 GBP
