Brosse en acier inoxydable 13 mm (531-2) 2 pièces
7.80 CHF*PVC TTC
Nettoyage / Polissage
Ideal for cleaning, deburring and surface-finishing items made from stainless steel, aluminum, silver, pewter or other white metals
  • It is very effective on flat surfaces and in hard-to-reach places, such as slots
  • Stainless steel wire bristles
  • Very effective on flat surfaces and in hard-to-reach places, such as slots
Voir toutes les variantes
7.80 CHF*
Tuyaux métalliques
Tôles
Métal tendre
Laiton
Acier durci
Or
Argent
Acier inoxydable
Fonte
Cuivre
tr/min
Stainless steel brushes do not cause after-rust when used on corrosive-resistant materials like pewter, aluminum and stainless steel. Ideal for cleaning, deburring and surface-finishing. Very effective on flat surfaces and in hard-to-reach places, such as slots. Pack includes two stainless steel brush accessories.
Diamètre de fonctionnement
Vitesse maximale
Contenu emballage
Prix
26150531JA
12,7 mm
15.000 tr/min
2 pièces
7.80 CHF*
  • Ideal for cleaning, deburring and surface-finishing items made from stainless steel, aluminum, silver, pewter or other white metals
26150532JA
15.000 tr/min
3 pièces
11.50 CHF*
Brosse en acier inoxydable 3,2 mm (532-3) 3 pièces
  • Pour nettoyer les matériaux résistants à la corrosion tels que l’acier inoxydable et l’argent.
Diamètre de la queue
12,7 mm
Longueur de l'accessoire
51,0 mm
Matériau
Brosses en acier inoxydable
Forme
Brosse boisseau
Utilisation du mandrin
Aucun mandrin nécessaire
15,0 mm
Vitesse maximale
15.000 tr/min
15,0 mm
Hauteur
50,0 mm
2
2
Outils multi-usage
Stylo+ DREMEL (2050-15)
Stylo+ DREMEL® (2050-10)
Bricolage
8710364070374
26150531JA
Dremel accessoire Brosse en acier inoxydable 531-2
Détails de la fourniture
  • 2 pcs
  • Longueur de l'emballage, 1.3 cm
