Accessory Kits
100 pieces DREMEL® Multipurpose Accessory Set (723)
Accessory Kits
Softwood
Hardwood
Plastic
Soft Metal
Copper
Sheet Metal
Plywood
The 100 pieces Dremel Multipurpose Accessory Set contains 100 high quality genuine Dremel accessories including EZ SpeedClic accessories which allow for quick and easy accessory changes. With this accessory set you can tackle a wide range of applications in a variety of different materials. The storage case allows you to conveniently store your Dremel accessories.
- Ideal Dremel starter kit with 100 accessories for various applications and materials
150 pieces DREMEL® Multipurpose Accessory Set (724)
- Ideal Dremel starter kit with 150 accessories for a wide range of applications and materials
EZ SpeedClic Cutting Accessory Set (SC690)
- Set of 10 EZ SpeedClic cutting wheels + mandrel for cutting in metals and plastics
EZ SpeedClic Multipurpose Accessory Set (SC725)
- Multipurpose kit with 70 high quality EZ SpeedClic accessories for various applications and materials
Cutting Set (688)
- Set of 68 cutting accessories to cut in a variety of materials
Multipurpose Set (687)
- Set of accessories for cutting, carving, sanding, cleaning, polishing, grinding and sharpening
Cleaning / Polishing Set (684)
- Ideal starter set for cleaning and polishing including 20 accessories
- Product box length, 4.5 cm
- Product box height, 23 cm
- Product box width, 19.5 cm
