Cleaning / Polishing
Brass brush 3,2 mm (537-3) 3 pieces
For cleaning soft metals like gold, bronze or copper.
  • Ideal for cleaning and surface-finishing items made from gold, bronze, copper or brass
  • Use a brass brush to create a soft, satin or matte finish
  • Very effective on flat surfaces and in hard-to-reach areas like slots (brass wire is non-sparking and softer than steel)
14.2 GBP
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
Shank diameter
Working diameter
3.2 mm
Accessory length
48.0 mm
Brass Brushes
Shape
Pen Brush
Mandrel use
No Mandrel Needed
5.0 mm
Maximum RPM
15,000 1/min
5.0 mm
Height
44.0 mm
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364045112
26150537JA
3 pieces Brass brush 3,2 mm (537)
Delivery details
  • 3 pc
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
14.2 GBP
