Sanding
EZ SpeedClic accessories
DREMEL® EZ SpeedClic: Detail Abrasive Brush 36 grit (471S)
Sanding
See all variations
10 GBP
Glass fibre reinforced plastics
Sandwich material
Brass
Copper
Plywood
Softwood
Chipboard
Hardwood
Laminates
Hardened Steel
Soft Metal
Stainless Steel
Plastic
What can you do with it?
Great for detail cleaning and light sanding. Allows sanding of contours, details, and hard-to-reach areas. Built-in polishing compound - rubber bristles have abrasive inside, no need for polishing compound. Removes exterior surface layer without damage to base layer below and removes the paint but not the wood with light pressure. Both abrasive brushes and buffs are available in fine, medium and coarse grades.
How to use?
Use with SC402 or 402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel (EZ SpeedClic mandrel SC402 and 402 sold separately). Abrasive Brushes are best used with the edge placed against the work piece, and do not require excessive pressure to see results. If the results are not strong enough, consider changing to one of the coarser brushes. Compatible with both the Dremel Exclusive SC402 EZ Lock mandrel and standard 402 mandrel.
Materials to use on
Suitable for use on wood, aluminum, plastic, metal, steel and vinyl.
Recommended speed
10.000-15.000 RPM
Shank diameter
Working diameter
Grit
Package contents
Price
2615S471JA
25,0 mm
1 piece
£10.00*
  • Great for detail cleaning and light sanding (Grit 36).
2615S512JA
25,0 mm
2 pieces
£7.00*
DREMEL® EZ SpeedClic: Finishing Abrasive Buffs 320 grit (512S) 2 pieces
  • For cleaning and light sanding of e.g. glass, wood, metal and plastic.
2615S472JA
25,0 mm
1 piece
£10.00*
DREMEL® EZ SpeedClic: Detail Abrasive Brush 120 grit (472S)
  • Great for detail cleaning and light sanding (Grit 120).
2615S473JA
25,0 mm
1 piece
£10.00*
DREMEL® EZ SpeedClic: Detail Abrasive Brush 220 grit (473S)
  • Great for detail cleaning and light sanding (Grit 220).
Shank diameter
Working diameter
25,0 mm
Thermoplastic with Aluminum Oxide Abrasive
Shape
Brush
Mandrel use
Compatible with EZ402, SC402 and 402
Grit
36
25,0 mm
Maximum RPM
15.000 1/min
25,0
Height
7,0
Suitable Dremel devices
Retired Products
Multi-Tools
8710364050314
2615S471JA
Dremel accessory 471S_EZ SpeedClic Detail Abrasive Brush 36 Grit
Delivery details
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
10 GBP
