Carving/Engraving/Routing
Structured Tooth Tungsten Carbide Cutter coned 7,8 mm (9934)
Structured Tooth Tungsten Carbide Cutter coned 7,8 mm Structured Tooth Tungsten Carbide Cutter coned 7,8 mm Structured Tooth Tungsten Carbide Cutter coned 7,8 mm
Very tough bit, for material removal of e.g. fiberglass, wood or ceramic tile.
£25.00* RRP incl. VAT
Example of usage
Technical details for Structured Tooth Tungsten Carbide Cutter coned 7,8 mm (9934)
  • Carbon Carbon
  • Leather Leather
  • Rubber Rubber
  • Drywall/Plasterboard Drywall/Plasterboard
  • Brick Brick
  • Brass Brass
  • Soft Metal Soft Metal
  • Softwood Softwood
  • Ceramic Ceramic
  • Hardwood Hardwood
  • Aluminium Aluminium
  • Cast iron Cast iron
  • Plastic Plastic
Technical specifications
Shank diameter
Working diameter
7,8 mm
Accessory length
40,0 mm
8,0 mm
8,0 mm
Height
40,0 mm
Maximum RPM
Package Contents
1 piece
Variations
Delivery details: Structured Tooth Tungsten Carbide Cutter coned 7,8 mm (9934)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
2615993432
8710364008575
