Grinding / Sharpening
Aluminum Oxide Grinding Stone 15,9 mm (8193) 2 pieces
Cylindrical shaped, aluminium oxide grinding stone with the largest diameter.
  • Specially designed for working with conic surfaces
  • For use on metals, castings, welded joints, rivets and rust
  • High-quality industrial abrasive rotary accessory
7 GBP
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
For sharpening, deburring and general purpose grinding on most materials including stainless steel. E.g. sharpening lawn mower blades, screwdriver tips, knives, scissors, chisels and other cutting tools. Use to remove flash from metal castings, deburring any metal after cutting, smoothing welded joints, grinding off rivets and removing rust.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
The orange grinding stones are for metal-like, ferrous materials, like stainless steel, aluminium, brass, copper.
Recommended speeds (RPM):
Aluminum: 20-30.000 Brass: 20-30.000 Copper: 20-30.000
Package contents
Price
26158193JA
2 pieces
£7.00*
  • Cylindrical shaped, aluminium oxide grinding stone with the largest diameter.
26150932JA
3 pieces
£8.50*
Aluminum Oxide Grinding Stone 9,5 mm (932) 3 pieces
  • Medium sized, cylindrical grinding stone. For grinding materials like metal.
26150953JA
3 pieces
£8.50*
Aluminum Oxide Grinding Stone 6,4 mm (953) 3 pieces
  • Small sized, cone shaped grinding stone. For grinding materials like metal.
26150952JA
3 pieces
£8.50*
Aluminum Oxide Grinding Stone 9,5 mm (952) 3 pieces
  • Medium sized, cone shaped grinding stone. For grinding materials like metal.
26158153JA
3 pieces
£8.50*
Aluminum Oxide Grinding Stone 4,8 mm (8153) 3 pieces
  • Smallest cylindrical shaped aluminium oxide grinding stone.
26150997JA
3 pieces
£9.00*
Aluminum Oxide Grinding Stone 3,4 mm (997) 3 pieces
  • Smallest cone shaped, aluminium oxide grinding stone with a flat tip for grinding materials like metal.
2615821532
1 piece
£3.20*
Aluminum Oxide Grinding Stone 25,4 mm (8215)
  • Thin cylindrical shaped aluminium oxide grinding stone with the largest diameter.
Shank diameter
Working diameter
15,9 mm
Accessory length
Aluminum Oxide
Shape
Cylinder
Mandrel use
No Mandrel Needed
20,0 mm
20,0 mm
Height
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044917
26158193JA
Dremel accessory 8193_Aluminum Oxide Grinding Stone 15,9 mm
Delivery details
  • Product box length, 3.5 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
7 GBP
