Grinding / Sharpening
Aluminum Oxide Grinding Stone 4,8 mm (8153) 3 pieces
Smallest cylindrical shaped aluminium oxide grinding stone.
  • Ideal for sharpening, deburring and general purpose grinding on most materials including stainless steel
  • Use on metals, castings, welded joints, rivets and rust
  • A high-quality industrial abrasive rotary accessory
8.5 GBP
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
For sharpening, deburring and general-purpose grinding on most materials including stainless steel. E.g. sharpening lawn mower blades, screwdriver tips, knives, scissors, chisels and other cutting tools. Use to remove flash from metal castings, deburring any metal after cutting, smoothing welded joints, grinding off rivets and removing rust. It is made from aluminum oxide for precision grinding and increased durability.
How to use?
Use the side of the accessory for the best finish at an angle. It can be used with all Dremel Multi-Tools or other 3,2mm shank size Multi-Tools. Can be restored to its original shape and cleaned through the use of a dressing stone. It is important to select the correct stone for the project. The best way to find the right stone for you is by using some scrap material to see the result. A general rule is that the flat stones are best for flat surfaces, and the curved stones will work with a wider variety of angles.
Material to use on
Suitable for use on metal-like, ferrous materials, like stainless steel, aluminum, brass, copper.
Recommended speeds
Aluminum 20.000-30.000 RPM Brass 20.000-30.000 RPM Copper 20.000-30.000 RPM
Package contents
Price
26158153JA
3 pieces
£8.50*
  • Smallest cylindrical shaped aluminium oxide grinding stone.
26150932JA
3 pieces
£8.50*
Aluminum Oxide Grinding Stone 9,5 mm (932) 3 pieces
  • Medium sized, cylindrical grinding stone. For grinding materials like metal.
26150953JA
3 pieces
£8.50*
Aluminum Oxide Grinding Stone 6,4 mm (953) 3 pieces
  • Small sized, cone shaped grinding stone. For grinding materials like metal.
26150952JA
3 pieces
£8.50*
Aluminum Oxide Grinding Stone 9,5 mm (952) 3 pieces
  • Medium sized, cone shaped grinding stone. For grinding materials like metal.
26150997JA
3 pieces
£9.00*
Aluminum Oxide Grinding Stone 3,4 mm (997) 3 pieces
  • Smallest cone shaped, aluminium oxide grinding stone with a flat tip for grinding materials like metal.
26158193JA
2 pieces
£7.00*
Aluminum Oxide Grinding Stone 15,9 mm (8193) 2 pieces
  • Cylindrical shaped, aluminium oxide grinding stone with the largest diameter.
2615821532
1 piece
£3.20*
Aluminum Oxide Grinding Stone 25,4 mm (8215)
  • Thin cylindrical shaped aluminium oxide grinding stone with the largest diameter.
Shank diameter
Working diameter
4,8 mm
Accessory length
Aluminum Oxide
Shape
Cylinder
Mandrel use
No Mandrel Needed
6,0 mm
6,0 mm
Height
Maximum RPM
25.000 1/min
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044931
26158153JA
Dremel accessory 8153_Aluminum Oxide Grinding Stone 4,8 mm
Delivery details
  • Product box length, 2 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
8.5 GBP
