Grinding/sharpening
Aluminum Oxide Grinding Stone 9,5 mm (952)
Medium sized, cone shaped grinding stone. For grinding materials like metal.
£6.00*
RRP incl. VAT
What can you do with it?
For sharpening, deburring and general purpose grinding on most materials including stainless steel. E.g. sharpening lawn mower blades, screwdriver tips, knives, scissors, chisels and other cutting tools. Use to remove flash from metal castings, deburring any metal after cutting, smoothing welded joints, grinding off rivets and removing rust.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
The orange grinding stones are for metal-like, ferrous materials, like stainless steel, aluminium, brass, copper.
Recommended speeds:
Aluminum 15000
Brass 15000
Copper 15000
Example of usage
Technical details for Aluminum Oxide Grinding Stone 9,5 mm (952)
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
Technical specifications
Shank diameter
Working diameter
9,5 mm
Accessory length
40,0 mm
10,0 mm
10,0 mm
Height
Maximum RPM
25.000 1/min
Package Contents
3 pieces
Suitable Dremel devices
Retired Products
Multi-Tools
26150952JA
8710364044894
Similar Accessories (5)
Delivery details: Aluminum Oxide Grinding Stone 9,5 mm (952)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
26150952JA
8710364044894
8710364044894
