Grinding / Sharpening
Chainsaw Sharpening Grinding Stone 4,8 mm (454) 3 pieces
Second to biggest chainsaw sharpening bit. Requires one spacer
  • Ideal for sharpening chain saw blades, quickly and easily
  • Keep a light touch; too much pressure can break the Grinding Stone
  • Precision ground abrasive stone
9 GBP
Chainsaw chain
What can you do with it?
Sharpen the tooth of the chain.
How to use?
When sharpening a chain saw, sharpen all of the teeth going in one direction, then with the saw in the same position, line the tool up with the second 30° mark and sharpen the teeth that run in the opposing direction. Always try to do the same tooth two or three passes across each tooth. Use the spacers for the best result. They are used to move the pink or orange stones away from the attachment – so they don’t contact the attachment during operation. The pink stone (the largest) requires both spacers. The orange stone (the middle size) requires one spacer. The blue/grey stone does not require any spacers.
Materials to use on:
Chains of chainsaw.
Recommended speeds:
Chainsaw Blade 30000
Package contents
Price
26150454JA
3 pieces
£9.00*
  • Second to biggest chainsaw sharpening bit. Requires one spacer
26150453JA
3 pieces
£9.00*
Chainsaw Sharpening Grinding Stone 4 mm (453) 3 pieces
  • Smallest chainsaw sharpening bit. Does not require spacers
26150455JA
3 pieces
£9.00*
Chainsaw Sharpening Grinding Stone 5,6 mm (455) 3 pieces
  • Biggest chainsaw sharpening bit. Requires the use of both spacers
26150457JA
3 pieces
£9.00*
Chainsaw Sharpening Grinding Stone 4,5 mm (457) 3 pieces
  • Second to smallest chainsaw sharpening bit.
Shank diameter
Working diameter
4,8 mm
Accessory length
50,0 mm
Aluminum Oxide
Shape
Cylinder
Mandrel use
No Mandrel Needed
5,0 mm
5,0 mm
Height
Maximum RPM
30.000 1/min
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044993
26150454JA
Dremel accessory 454_Chainsaw Sharpening Grinding Stone 4,8 mm
Delivery details
  • Product box length, 1 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
9 GBP
