Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Grinding / Sharpening
Chainsaw Sharpening Grinding Stone 5,6 mm (455-3) 3 pieces
Biggest chainsaw sharpening bit. Requires the use of both spacers
  • Ideal for sharpening chainsaw blades quickly and easily
  • A precision-ground abrasive made for extended usage
  • Includes 2 grinding stones
9.4 GBP
Chainsaw chain
What can you do with it?
Sharpen the tooth of the chain.
How to use?
When sharpening a chain saw, sharpen all of the teeth going in one direction, then with the saw in the same position, line the tool up with the second 30° mark and sharpen the teeth that run in the opposing direction. Always try to do the same tooth two or three passes across each tooth. Use the spacers for the best result. They are used to move the pink or orange stones away from the attachment – so they don’t contact the attachment during operation. The pink stone (the largest) requires both spacers. The orange stone (the middle size) requires one spacer. The blue/grey stone does not require any spacers
Materials to use on:
Chains of chainsaw
Recommended speeds:
Chainsaw Blade 30000
Package contents
Price
26150455JA
3 pieces
£9.00*
  • Biggest chainsaw sharpening bit. Requires the use of both spacers
26150453JA
3 pieces
£9.00*
Chainsaw Sharpening Grinding Stone 4 mm (453-3) 3 pieces
  • Smallest chainsaw sharpening bit. Does not require spacers
26150454JA
3 pieces
£9.00*
Chainsaw Sharpening Grinding Stone 4,8 mm (454-3) 3 pieces
  • Second to biggest chainsaw sharpening bit. Requires one spacer
26150457JA
3 pieces
£9.00*
Chainsaw Sharpening Grinding Stone 4,5 mm (457) 3 pieces
  • Second to smallest chainsaw sharpening bit.
Shank diameter
3.2 mm
Working diameter
5.6 mm
Accessory length
50.0 mm
Aluminum Oxide
Shape
Cylinder
Mandrel use
No Mandrel Needed
6.0 mm
6.0 mm
Height
39.0 mm
Maximum RPM
30,000 1/min
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364045006
26150455JA
3 pieces Chainsaw Sharpening Grinding Stone 5,6 mm (455)
Delivery details
  • 3 pcs
  • Product box length, 1 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
9.4 GBP
