Carving / Engraving
Diamond Wheel Point 4,4 mm (7105-2) 2 pieces
Carving / Engraving
Biggest ball shaped diamond bit, for engraving in hard material
  • Ideal for fine detail work on wood, ceramic, glass, hardened steel and other hard materials
  • Diamond particle coating for increased durability
  • Use higher speeds for hard woods and slower speeds for metals
See all variations
25 GBP
Carbon
Leather
Rubber
Plastic
Brick
Soft Metal
Softwood
Hardwood
Glass
Copper
Silver
Gold
Brass
Ceramic
Porcelain
Shank diameter
Working diameter
Accessory length
Package contents
Price
26157105JA
4.4 mm
46.0 mm
2 pieces
£24.50*
  • Biggest ball shaped diamond bit, for engraving in hard material
26157103JA
2.0 mm
45.0 mm
2 pieces
£17.00*
Diamond Wheel Point 2 mm (7103-2) 2 pieces
  • Smallest ball shaped diamond bit, for engraving in hard material
26157122JA
2.4 mm
46.0 mm
2 pieces
£15.00*
Diamond Wheel Point 2,4 mm (7122-2) 2 pieces
  • Small cylindrical shaped diamond bit, for engraving in hard materials
26157134JA
2.0 mm
46.0 mm
2 pieces
£17.00*
Diamond Wheel Point 2,0 mm (7134-2) 2 pieces
  • Thin flat head diamond bit, for detailed engraving in hard materials
26157144JA
2.4 mm
46.0 mm
2 pieces
£16.00*
Diamond Wheel Point 2,4 mm (7144-2) 2 pieces
  • Conical / pointed head diamond bit, for detailed engraving in hard materials
Shank diameter
Working diameter
4.4 mm
Accessory length
46.0 mm
304 Stainless Steel
Shape
Ball
Mandrel use
No Mandrel Needed
4.0 mm
4.0 mm
Height
46.0 mm
Maximum RPM
25,000 1/min
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044849
26157105JA
2  pieces Diamond Wheel Point 4,4 mm with the Biggest ball shaped diamond bit, for engraving in hard material
Delivery details
  • 2 pcs
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.3 cm
25 GBP
