Carving / Engraving
Diamond Wheel Point 2,4 mm (7144) 2 pieces
Carving / Engraving
Conical / pointed head diamond bit, for detailed engraving in hard materials
  • Ideal for fine detail work on wood, jade, ceramic, glass, hardened steel and other hard materials
  • Removes material quickly and easily
  • Covered with diamond particles
See all variations
16 GBP
Carbon
Leather
Rubber
Plastic
Brick
Soft Metal
Softwood
Hardwood
Glass
Copper
Silver
Gold
Brass
Ceramic
Porcelain
Shank diameter
Working diameter
Accessory length
Package contents
Price
26157144JA
2,4 mm
46,0 mm
2 pieces
£16.00*
  • Conical / pointed head diamond bit, for detailed engraving in hard materials
26157122JA
2,4 mm
46,0 mm
2 pieces
£15.00*
Diamond Wheel Point 2,4 mm (7122) 2 pieces
  • Small cylindrical shaped diamond bit, for engraving in hard materials
26157134JA
2,0 mm
46,0 mm
2 pieces
£17.00*
Diamond Wheel Point 2,0 mm (7134) 2 pieces
  • Thin flat head diamond bit, for detailed engraving in hard materials
26157105JA
4,4 mm
46,0 mm
2 pieces
£24.50*
Diamond Wheel Point 4,4 mm (7105) 2 pieces
  • Biggest ball shaped diamond bit, for engraving in hard material
Shank diameter
Working diameter
2,4 mm
Accessory length
46,0 mm
304 Stainless Steel
Shape
Small Taper
Mandrel use
No Mandrel Needed
Height
46,0 mm
Maximum RPM
25.000 1/min
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044870
26157144JA
Dremel accessory  7144_Diamond Wheel Point 2,4 mm
Delivery details
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.3 cm
16 GBP
