Corded Tools
Multi-Tool – Strong. Dynamic. Maximum control.
Strong and dynamic Multi-Tool for everyday use
Tackle your precision carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning projects with just one tool
Experience maximum control and precision with the most variable rotary speed (5.000 – 35.000 RPM)
1 attachment and 45 accessories included. Get started straight away
This kit includes the high performance 4000 Multi-Tool, with innovative features like the EZ Twist nose cap, electronic feedback, collet lock out function and an RPM range of 5.000 to 35.000. Additionally the kit includes the Flexshaft attachment, which is the ideal attachment for detailed work on hard to reach places. Next to the Flex Shaft attachment the kit includes 45 original Dremel accessories including EZ SpeedClic.
Example of usage
Technical details for DREMEL® 4000 (4000-1/45)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Battery technology
No load speed (3)
Speed setting
Fully Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
Included Accessories (35)
Overview of prices and Kit content
Order number: F0134000JB
EAN Code: 8710364048175
£100.00
Dremel 4000
45 high quality Dremel accessories (including EZ SpeedClic starter set)
High quality Flex Shaft (225)
Instruction manual
Soft bag
Product box length, 25.8 cm
Product box height, 28.7 cm
Product box width, 8.7 cm
Gross weight, 1,79 kg
Order number: F0134000JR
EAN Code: 8710364074730
£130.00
Dremel 4000
65 high quality Dremel accessories in Mini Accessory Case (including EZ SpeedClic starter set)
Flexshaft attachment (225)
Pencil grip nose cap
Line & Circle Cutter attachment (678)
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
Instruction manual
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your project
Product box length, 398.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Gross weight, 2,82 kg
Order number: F0134000KF
EAN Code: 8710364057955
£210.00
Dremel 4000
128 high quality Dremel accessories
Right Angel attachment (575)
Cutting Guide attachment (565)
Instruction manual
Aluminum carry case
Product box length, 43.7 cm
Product box height, 23.6 cm
Product box width, 24.3 cm
Gross weight, 6,00 kg
