Corded Tools
Multi-Tool – Strong. Dynamic. Maximum control.
This Dremel kit includes the high performance 4000 Multi-Tool with the new EZ Twist Nose Cap. This means no wrench is needed anymore when changing accessories. It comes in a practical carrying case which contains the Flex Shaft, the Line & Circle Cutter, the detailer’s grip and the shaping platform attachment. Furthermore 65 original Dremel accessories are included.
Technical details for DREMEL® 4000 (4000-4/65)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Battery technology
No load speed (3)
Speed setting
Fully Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
77,9 dB(A)
Sound power
88,9 dB(A)
Vibration
2,6 - 11,4 m/s²
Included accessories (51)
Overview of prices and Kit content
Order number: F0134000JE
EAN Code: 8710364048205
See Kit content
Dremel 4000
65 high quality Dremel accessories in Mini Accessory Case (including EZ SpeedClic starter set)
High quality Flex Shaft
Pencil grip nose cap
Shaping Platform
Detailer’s Grip
Instruction manual
Spacious and sturdy storage case
Product box length, 26.8 cm
Product box height, 39 cm
Product box width, 10 cm
Gross weight, 2,70 kg
DREMEL® 4000 (4000-4/55)
Order number: F0134000UB
EAN Code: 8710364080694
See Kit content
DREMEL® 4000
57 high quality Dremel accessories
Flexshaft attachment (225)
Line & Circle Cutter attachment (678)
Cutting Guide attachment (565)
Detailer's Grip attachment (577)
Aluminum carry case
Accessory holder
Accessory information sheet
Instruction manual
Product box length, 23.3 cm
Product box height, 18.6 cm
Product box width, 36.5 cm
Gross weight, 3,40 kg
DREMEL® 4000 (4000-1/45X)
Order number: F0134000UN
EAN Code: 8710364081462
See Kit content
Dremel 4000
45 high quality Dremel accessories (including EZ SpeedClic starter set)
Detailers grip
Plastic toolholder
2x Accessory holder
Instruction manual
Plastic Tool case
