Sanding
DREMEL® EZ SpeedClic: Detail Abrasive Brush 220 grit (473S)
DREMEL® EZ SpeedClic: Detail Abrasive Brush 220 grit DREMEL® EZ SpeedClic: Detail Abrasive Brush 220 grit
Great for detail cleaning and light sanding (Grit 220).
£8.00* RRP incl. VAT
What can you do with it?
Great for detail cleaning and light sanding. Allows sanding of contours, details, and hard-to-reach areas. Built-in polishing compound - rubber bristles have abrasive inside, no need for polishing compound. Removes exterior surface layer without damage to base layer below and removes the paint but not the wood with light pressure.
Both abrasive brushes and buffs are available in fine, medium and coarse grades.
How to use?
Abrasive Brushes are best used with the edge placed against the work piece, and do not require excessive pressure to see results. If the results are not strong enough, consider changing to one of the coarser brushes.
Compatible with both the Dremel Exclusive SC402 EZ Lock mandrel and standard 402 mandrel
Materials to use on
Sand and Clean wood, aluminum, plastic, metal, steel and vinyl
Recommended speed
Maximum RPM: 15.000 RPM
Technical details for DREMEL® EZ SpeedClic: Detail Abrasive Brush 220 grit (473S)
  • Glass fibre reinforced plastics Glass fibre reinforced plastics
  • Sandwich material Sandwich material
  • Brass Brass
  • Copper Copper
  • Plywood Plywood
  • Softwood Softwood
  • Chipboard Chipboard
  • Hardwood Hardwood
  • Laminates Laminates
  • Soft Metal Soft Metal
  • Aluminium Aluminium
  • Plastic Plastic
  • Mandrel Mandrel
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
25,0 mm
Grit
220
25,0 mm
Maximum RPM
15.000 1/min
25,0
Height
7,0
Package Contents
1 piece
Variations
Delivery details: DREMEL® EZ SpeedClic: Detail Abrasive Brush 220 grit (473S)
Product box length, 1.5 cm
Product box height, 10 cm
Product box width, 5 cm
2615S473JA
8710364050338
